Hoping someone with a 2005 bulldog can chime in (i believe the 05 Mastiff is the same frame)
I lost the main bolt that goes through the top of the coil cover and attaches to the frame. What size is it? 1/2 x20 x 1/34.
Also there is a 3/8 inch gap now between the frame and coil cover. Does this space take a washer or does the bolt just tighten the cover right to the frame.
How about washers.. I read somewhere that fiberglass washers should be used. The other side has a spiked nut. I attached some pics
Any help would be appreciated.
Nuno
Nuno
