Mario77746
Well, I got back from Daytona and noticed I had to put my toe under the shifter to pull it back up. It did this a few times then today it stuck almost every time I pressed down. I figure it may be sand from the beach in the fwd control but have not ripped it apart yet. Anything else I should be concerned about or looking for when I tear this down on Saturday?
Thanks.
Thanks.
check out the heim joints on the ends of the shifter linkage. clean and re-lube, or replace with new ones with brass inserts. also check on the alignment of the ends; should be within a few degrees of each other. :2thumbs:
:roll:
