Clutch setting
ohiobackground
When I try to engage my clutch, it's almost impossible to squeeze. Is there a setting for tension or tightness I can loosen but still operate the same ?
Bike: 2007 Big Dog Mastiff
as far as a setting to lighten the pull of the clutch, no. as said before, go through the adjustment procedure and check to make everything right. lube the rod, the ball & ramp, the clutch cable, everything. and make sure you use the correct lube for each item. if this doesn't work, go to the gym. :D:D:cheers:
by the way, NICE INTRO.
kmalysa
Also the ball ram on right side that controls the Clutch rod, may be jambed or miss-alighned. Don't ask me how I know.
Five Five
had the same problem on my Pitbull ...ended up being my clutch hub nut backing off.... once I tightened it up it worked fine... go through your clutch circut from cable to nut make sure everything is right..
