Once again thanks for the info/advice/tips everyone :up:
fyi- I believe the the impact wrench does 400 ft.-lbs.
I went out and got a torch and that did the trick. Both the clutch nut and the engine sprocket nut came off just fine.
After I removed the entire clutch assembly I noticed a slow and steady stream of transmission fluid leaking into the primary case from the transmission shaft. I think that's normal. I put the clutch basket back in for now to keep it from leaking more.
My open primary won't get here until sometime tuesday.. Should I drain the tranny fluid and get a bottle of redline pepto and refill after installing the new primary? Or will there still be enough tranny fluid left if I just let it leak out until it stops
