John M Kovarovic
Greetings to all. In spite of world events, hope everyone is doing okay…
I am new to the forums and BDM. I have a 06 K9 that is giving me some problems. Hopefully, that can be resolved with the talent available here…
My issue is the clutch. I can’t get it to work (correctly). Start the bike, pull the clutch lever, hit the shifter peg and the bike dumps. It’s as if I just hit the shifter without using the clutch. Bike goes into gear and stalls out…
I’ve tried adjusting the clutch in accordance with the manual and procedures that I have found in the forums. Nothing works. I’ve replaced the cutch cable, clutch push rod, ball and ramp, clutch pack, throw-out bearing, pressure plate I know that the clutch pack steel plates have rounded edges on one side and sharp on the other (in all cases, plates are installed with the sharp edge towards the transmission). A bit frustrating. I’m starting to think I need to replace the entire clutch assembly…
In any event, any suggestions/ideas would be most appreciated…
Thanking everyone in advance…
John
John
