Greyhairracer
Help!!!! Was getting ready to install new clutch in doggie and discovered the basket is very loose; how it cam to be this way has yet to be determined.
Regardless, I was going to pull the center hub out to get to the root cause and can't get the damn bolt of the hub. Tried using impact gun going both ways - won't budge. Don't see a washer behind that's bent down to keep it from moving, so I'm at a loss as to why it won't come loose.
Looks like there's holes on the parameter of the basket for what I assume is a clutch tool? What do I need to do here....get a tool then put a breaker bar on it to get the nut loose??
I'm beating my head into the wall trying to get this damn nut off....can't run it with a loose basket, so I'm at a loss.
Any help would be greatly appreciated!!! Also, if anyone might have a '05 Bulldog service manual in pdf I can download that would be most helpful as well.
Trying to get back on the road.....help please!!!!!!
Gracias!!!!
Gracias!!!!
