bryant1609
Ever sense I installed my Karata belt my clutch cable appears to be too long now. There is now not enough adjustment I can do with the adjuster to get the clutch pressure back to what it was before I installed the Karata. To make up the needed adjustment I had to add three washers to get the cable tight enough. Mine you after that the clutch work as before but now I’m getting ready to take a long trip and was wondering if I should just change the cable now. But my thinking is that if I change the cable it maybe have the same issue which would require me to do the same fix. The bike only has about 16K on it and the cable was replaced once after 500 miles when the Eye Let broke.
