clutch cable problem
lineman 112
Had to replace drive belt today took everything off tire,exhaust,and the housing for drive belt which is also where clutch cable goes into. So get new belt on n put housing back on n thats when i notice have all sorts of slack in clutch cable its like somthings not releasing to allow tension in clutch cable. Any ideas or info would be great. Thought the cable had broke at first but it didnt
Brew
Sounds like your Ramp and ball assembly moved on you while you had the actuator assembly off...
dingo
First 50
Open the ball ramp assembly on the inside of the actuator (5 allen screws), reset the ball / ramp, and reinstall.
