kmalysa
I need some help. I need to remove my clutch basket, chain and drive sprocket so I can remove my inner primary cover to replace 'o' rings (due to oil leak).
My manual shows a Clutch Hub nut and washer holding the clutch basket in place. However if you look at the photos attached, I have no such nut and washer and no threaded place that one would go????
I bought the bike used, is this an after market clutch pack? If so I need to identify it and get removal instructions. I want to remove as one assembly. This is an '05 117CI with Baker 6speed RHD
