98sporty
Had the seal leaking behind pulley and tore everything down to replace it. Had a heck of a time getting the clutch rod cover off. It was super tight. I was thinking that the rubber o-ring was making it stick. Has anyone else had any trouble removing it?, If so what methods did you use to remove it, and should I use something to lubricate the o-ring?
TIA
TIA
