will_65466@live.com
So i searched all over the forum and found CURDOG post. It was identical to the problem that im having. If you havent read his post to basically sum it up hit the run and all you hear is a click from the CR. The only difference is his fix was to upgrade to a new wire harness. what is kickin my ass is i already have the wire plus:bang: So my issue is i get no power to my little green wire to the starter. Is it possible to bypass the relay to get power? or do i have to replace that part of the harness, any help[ would be awesome.
i had my poor dog all torn apart wires everywhere. Mutimeter, jump wires, test light you name it everywhere. i found my problem by mistake:loony: so im testing and checking things and decided to start all over. So i went to pull my green starter wire off one more time to check volts and wouldent you believe it i pulled the wire right outta the crimp.:angry: So i cut and crimped a new one on tested the volts and POW its reading 12 volts when i hit the start button. So i plug it in hit the button and Vroom! this dog fires to life.
So i had this whole time a loose wire inside a crimp socket. It was soldered in and broke inside where you couldent see and was able to be plugged in and out several times and not break all the way. Thanks for hangin in with me on a Sunday Mr. Wright.:flag:
