Bigdogchop04
Here’s a few pictures of Harley / kuryakyn longhorn offsets for passenger pegs. The big dog pegs will not work as they are too wide to mount in these so you will have to use new pegs also. I used the main bolt from the offsets which is 1/2 (same as stock) and bolted directly to the peg mount on the frame. The upper/front part clears the oil tank by 1/16-1/8”. My wife sat on the bike and pushed hard enough to lift her rear and they didn’t move. Hdm and others don’t have the Vance and Hines relocation kit anymore than moved the pegs higher to clear the exhaust so this will be an option if need be for someone. This is ambush exhaust and I needed maybe 1/2” higher to clear the tip.
