Chirping sound
Badazz
So i have redone everything from the triple tree forward. And it still makes a chirping sound everytime I shift or let off the throttle. It sounds like it is coming from the triple tree but all redone and still there. Any ideas?
I'm going to walk the noise, see if it makes logical sense. I've [assume] repacked the triple with grease, inspected the bearings for 'chrip,' figured a lube would make it quiet on the lift and load at the throttle. While the front wheel was off, I lubed the wheel bearing seals, thinking the 'chirp' would be here at the on/off of the throttle. Even lubed the throttle cable and tube so this whole front end work did not stop the chirp.
That's what I said. Everything forward, but I can't see a lift is going to squeak a wheel seal, or a front end knock is replaced by a chirp.
But if I think chirp, and if chirp still represents a rubber component like a sneaker on a wooden floor chirp, let the clutch out on the car too fast the tire chirps?
So if I apply the lift and load as a chrip, I'm pointing to a rubber belt being pleasantly worn out equally with the sprocket tooth. That means if I'm diagnosing the word 'chrip,' it sounds like the belt tooth rides up on the sprocket tooth on lift, then moves back to the load side of the tooth on the return to open throttle is the other chirp.
1. Belt too loose?
2. Sprocket and belt teeth look worn?
3. Double You Dee Forty to the rescue?
4. Pepper me forty a little, or soap de jour?
Signed,
Busting Your Chops Club
Ears To Ya (beer bottles 'clink')
Badazz
So it went away for a bit with the soap on the belt, alignment problem I take it? So what is the best wayto get it realligned on a 04 mastiff?
Post a picture of your rims. 03-04, some designs squeaked. HDM has new Teflon coated pulleys,
Steven Proctor
I had similar issue on my 06 K9. I have a chrome belt guard on mine. The belt was rubbing ever so slightly on the guard. Like HMAN said, I rubbed soap on both sides of the belt all the way around. This solved the problem. So I then adjusted the belt guard so the belt wouldn’t rub. This solved my issue.
DynoDave
I had the same problem with my '02 Mastiff. Like you, I couldn't figure it out and consulted others on this forum to troubleshoot. Soap on the belt made the issue go away temporarily. Turns out the rear pulleys on the earlier models wore out fairly quickly. Looked for a replacement but couldn't find one like the original (matches the wheels). On the recommendation of others here I sent my pulley to Supermax to have their new teeth installed. Expensive, but couldn't be happier with the result.
