blue knight
I have an 06 BD K-9 with mean mother supertrapp pipes. I have heard a chirping noise coming from the exhaust when I hit speeds between 50-80 mph. Has anyone out there experienced this problem with there exhaust?
If your sure it's not your belt chirping (can be detected by spraying with some silicone spray) then check your exhaust shields as they have been known to come loose in addition to what was recommended above.I have an 06 BD K-9 with mean mother supertrapp pipes. I have heard a chirping noise coming from the exhaust when I hit speeds between 50-80 mph. Has anyone out there experienced this problem with there exhaust?
What Ray said!If your sure it's not your belt chirping (can be detected by spraying with some silicone spray) then check your exhaust shields as they have been known to come loose in addition to what was recommended above.
Dead nailed this one with his comment that Chain nailed it! When my wife's belt "chirped" it was always at lower speeds, but Ray has the miles under his seat and a bar of soap is a cheap way to eliminate the belt if that's what it is.You're not anywhere BadBrad's house are you?
http://www.bigdogbiker.com/forums/technical/15892-battery-melted-help.html Page 2, post #28 on.
j/k knight
Chains Right on top of this one! :2thumbs:
I am assuming by previous posts and thread that YOURS would be the Soap-on-a-Rope!!! Just Sayin:roll:Dead nailed this one with his comment that Chain nailed it! When my wife's belt "chirped" it was always at lower speeds, but Ray has the miles under his seat and a bar of soap is a cheap way to eliminate the belt if that's what it is.
My cajun brother! Don't lower yourself to Dead's standards.I am assuming by previous posts and thread that YOURS would be the Soap-on-a-Rope!!! Just Sayin:roll:
