Hey guys , I am putting my front end back together and trying to check fall away. I can get the non-caliber side to fall at 2 inches but the caliber side wants to fall almost right away. I have to tighten the stem nut pretty tight for the caliber side to fall around 2 inches but then the other side wont fall until around 3 inches. It seems I just cant get both sides close to fall at around the same mark.
I had to take off the clutch cable from the handle bars because it was interfering but I still get the same results.
I read several manuals and they say to loosen the stem nut but then both sides fall hard right away.
Raise the bike
take off clutch cable
take out set screw
loosen lower triple tree pinch screws
I even took off the brake line guide on the triple tree.
Its really heavy to the caliber side.
test then loosen or tighten triple tree cap nut to set adjustment.
Can anyone tell me what I am doing wrong?
Raise the bike
take out set screw
