bigdogtech01
Yes you should start your bike and let it run up to operating temp. Turn the bike off. Then drain your oil tank, engine case, and change the oil filter ever oil change. Just be careful to not over torque the drain plug on the bottom of the engine case..... well both that and the oil tank as well. I have had a few on the oil tank F-d up by customers, had to extract them and it can be a bit of a challenge if it is extremely tight.I was told not to pull the motor plug. I realize some of the old oil will remain, but are you saying that you should remove both the tank plug and the engine plug?
Is it safe to start the motor to circulate the oil into the motor or just crank it over for the oil to get in the motor without starting it?
Clean the threads on all the oil plugs and put a small amount of liquid pipe thread sealant onto the threads before reinstalling them. This will help to make sure the plugs do not leak. ( you do not need a lot, just a small amount, NOT a huge gob )
