It works for me. You might have to go to Big dog bikes friends on Facebook and sign up for the group.. Let me see if I can do better.Can't access the link?
Got it pknowlesCan't access the link?
Looks like it broke since then..seems like a fair dealWell, it's on CL for $10k
https://evansville.craigslist.org/mcy/d/2003-big-dog-chopper/6232977799.html
Ya depending on what the issue is, it's a good deal.Looks like it broke since then..seems like a fair deal
No but he mentions its new. Must have put a new one in which might be an interesting story you gotta beat on those transmissions pretty darn good to Fuck it upWas a six speed stock in 2003? Is that paint orange or pink?
I wonder how that would affect the gearing? Would that trans be an overdrive?No but he mentions its new. Must have put a new one in which might be an interesting story you gotta beat on those transmissions pretty darn good to Fuck it up
Depends on which one he went with its possible it could be an OD 6th gear like what came stock in the 2004 and later models.I wonder how that would affect the gearing? Would that trans be an overdrive?
Interesting. I quess you would have to ride it to see wher it was. Is high gear on a five speed direct?Depends on which one he went with its possible it could be an OD 6th gear like what came stock in the 2004 and later models.
Overall there should be no significant difference in gearing swapping 5 gears with 6 other than when you get to cruising at 80MPH.
There's tons of aftermarket kits that you can swap out the Gear set to the point you don't even have to remove the transmission
Yes guys my 2003 came with a 6-speed in it as well but of course after I picked it up in 2008 the Thunderheart was failing on me didn't leave me stranded anywhere but I knew I was having problems with the ignition so what do I do time to 86 that issue I put a Morris Magneto on the bike still have it Best Choice ever made and after I did that he would like to computer with searching for the ignition it would make my turn signals blink at random left or right did it matter so I reverse the ones on my triple trees so I can see which one was blinking or not don't want no one not knowing what I'm doing got tired of that idiotic deal and I totally stripped the complete wiring harness out of it it made it really easy no computer just like five or six wires coming off of the battery two circuit breakers. This was all back in 2008 2009 and I haven't had a problem with it since so my guess is..., it's the electrical problem that these are notorious for and it would be a simple fixWas a six speed stock in 2003? Is that paint orange or pink?
