Case stud length?
Chippy Chad
Does anyone happen to know what the case stud length is supposed to be on the tp107 and what the acceptable tolerance is? I pawed through my manual but I can't find it. Do most guys replace them when they do a top end rebuild? My bike has 12k miles on it. Thanks!
I just looked through the s&s manual and it does not give the length. You may want to give s&s a call. You probably don't need to replace the studs unless they are warped. Cover them with tubing to prevent them from getting damaged. Look at Raywoods top end rebuild how to. I believe he has the tp rockers as well.
Chippy Chad
Thanks for the reply, I just found a thread on this over on the performance forum. I am going to leave them alone.
