Bigbass
I did a winter rebuild of 650cam with 640 springs
port and polish heads
zero decked and diamond cut
new rings and wrist pins
new triple x carb with thunder jet ( I told him I had the radius pipes when I bought the carb.
swtiched from big radius pipes to short fuelies with torque cones I purcahsed seperatly( I have not changed jets since the pipe change )
Here is the question I was adjusting the carb and noticed front pipes turned blue really fast. The back pipe never changed color. I got the carb set fairly close where it responded okay for now. Ran the motor for a total of 30 minutes on the stand . I have not riden it just wanting to get motor right before i ride.
I pulled the pipes off to make a mount bracket for the short pipes and noriced there was a ton of carbon on front pipe but back pipe had none.
What would cause the front to build carbon but not the back. Did I not get Valve adjusted right or do I have a ring problem. Do I just need to adjust carb. The motor makes no niose and seems to run great. The lifters had tick before the build but now there is no tick at all.
Do I need to just put the radius back on. The motor starts and runs great but when I het throttle I do notice black smoke in front pipe and not rear. I would appreciate any suggestions. If it is a carb adjustment then what would cause it only to be in front cylinder.
I want to learn everything about thise motor so any suggestion would be great,
