Carb plug located below choke
kfoss8
Ok was wondering if someone could help me here i was told to pull the little black plug screw below the choke knob on the bottom side of carb i did that and fuel did come out wich they told me it wouldnt and rideing it was undriveable it just coughed all the time, so i put it back in and it ran fine. Now i sent my carb to XXX carbs they redid my carb and when he sent it back he left that plug out also what is the reason for taking it out i found it didn't work that way for me last time so i put it back in again. any help on this topic is much appreciated thanks.
kickstart
If you are talking about your Bowl vent plug you may need to remove it depending on the type of AC you are using.
kfoss8
ya that is it bowl vent plug i am running the forcewinder intake but with a 6" K&N breather on it when i take out that screw it does blow gas out of it and it ran like crap. So i put it back in but now that XXX modified my carb for me he sent the carb back without that vent screw in
kickstart
Go to the S&S site and download the Carb Manual about 30 pages and Free and it will enlighten you about many things one being Bowl vents. :)
