Thanks! I am just replacing the elctronics not the housing. What do you meanIf it is the exact same speedo...you take the speedo pod lose (look under bracket for 2 socket screws). then disassemble the pod by removing the screw under the pod. Tach ring and speedo coms out...unplug and swap out after loosening screw that hold tach ring/speedo together. Hope this helps. Good luck! BTW...if you are also replacing the POD...I believe you will have to remove the tank.
Its a mastiff 2009What year / model is your scoot ?
