Basically, a cam sensor is pulse readout. Coil wires waiting for a magnet to sweep over it real close.
While I understand what you're saying Sven and there are some types of inductive pickups that do use a magnet to sweep its "field" through a coil as you suggest, the cam sensor in a Big Dogs is a Hall Effect device that uses a slotted cup to break the magnetic field created by the sensor itself.
This part we agree on! :up:
...set it to 'a/c' volts.
And from here on out we disagree on cam sensor troubleshooting.
Here's how you separate the good from the bad cam sensor...
1. Disconnect the cam sensor from the ignition module.
2. Take out your trusty multimeter and set it to the RX1 scale.
3. Now while touching the sensor backing plate with the negative meter lead touch the positive meter lead on each of the three wires of the sensor connector (red, black, & green). If you get continuity from the backing plate to any of them the sensor is bad.
If it passes the first test...
1. With your meter still at the same settings touch the positive meter lead to the green wire and the negative meter lead to the black wire. If you get an "open" it's good. (Any resistance is "bad")
2. Then take the positive meter lead and touch the black sensor wire while touching the negative meter lead to the green wire. In this case an "open" is bad. A reading somewhere around 300 - 750 Kohms is what you're looking for.
So what values did you get in each step?
Dennis
