Alexey
Hi guys. I checked the oil level on my motorcycle and saw that it was less. I poured a little bit to the lower level of the filler neck. Check the air filter there is no oil, check all connections and gaskets are all dry, measure the compression of 12 bar-which is very good! I started and warmed motorcycle engine . The smoke from the muffler is not. Where would the oil go away? I fill in synthetic oil Motul 20v50. And you add oil to the engine?
