Bust a Nut!
DynoDave
Machinist's Workshop MagT recently published some information on various
penetrating oils that I found very interesting. Some of you might appreciate
this. The magazine reports the break out torque values on rusted nuts using
the tested penetrating oils.
Results are below, as forwarded by an ex-student and professional machinist.
They arranged a subjective test of all the popular penetrates with the
control being the torque required to remove the nut from a "scientifically
rusted" environment.
*Penetrating oils ....Average torque load to loosen*
No Oil used .................. 516 pounds
WD-40 ........................... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ............ 127 pounds
Kano Kroil .................... 106 pounds
ATF*-Acetone mix......... 53 pounds
The ATF*-Acetone mix is a "home brew" mix of 50% - 50% by volume automatic
transmission fluid and acetone. Note this "home brew" released bolts better
than any commercial product in this one particular test.
Our local machinist group mixed up a batch and we all now use it with
equally good results.
Note also that "Liquid Wrench" is almost as good as "Kroil" for about 20% of
the price!
Steve from Godwin-Singer says that the ATF*-Acetone mix is best, but you can
also use ATF* and lacquer thinner in a 50-50 mix
Mad Dog
ValueTeck Enterprises
The Kano Kroil oil is great for cleaning firearms also. Does a real nice job of removing copper and lead from the barrel. Just soak it good and let it sit overnight then brush and wipe clean.
Nukeranger
Nukeranger
:whoop::whoop::whoop:Damn good information here. That's it! I am going to use my Kroil for my firearms and mix up a batch of 50/50 ATF and Acetone for busting nuts.
Thanks guys,
Some fantastic intelligent sharing people on this forum:cheers::2thumbs::2thumbs::2thumbs:
Huw
Just any old ATF fluid, eh? That's a hell of a good deal that mixture will be a lot cheaper than buying any of those other fluids.
john sachs
Where a penetrate will work, Kroil is the best I've found. :2thumbs:
John
