broken yelloww wire??
mml03102
All the wires for that group going to the module have all been splice so Im going to try to connect that other yellow to the othe 2 yellows ,hope it doesn't short anything
Brew
I think that would be a safe bet seeing as how you get power to that yellow wire upon pushing the run button. What did they say had to be repaired on the module?
mml03102
It was a broken pin on the module ,probably happened when I put the new sensor in and testing the wires for power, I just tried connect that yellow to the yellow on the module and still nothing .
I think this rookie has had enough. Im going to try to get it in the shop this week and hopefully they can find the problem??
If I were to install the wire plus fit , would I be replacing the ignition at the same time or would I still be using the one I have?
You can still use the existing TH ignition. You should also have the option to use your existing key switch.
mml03102
Believe it or not I just now got my bike back , with a new coil and a dual fire ignition system. The bike has never started so smoothly after a year of trying to figure out the problem , problem seems to be solved and I am on the road again !!:whoop: :cheers:
mml03102
LOL Dennis , And yes they did they said it was piggy backed on the other yellow going to the ignition module but that still wasn't good enough, he said he would get it running and it would cut out and then not start is why we went with the dual fire ignition but any , just got in from riding, and is it hot out there today!!
