Breaking clutch cables
okred696
clutch cable broke, got a new one and all seemed to be working and first time out it is broken again. What are the things I need to check ?
make sure the ball and ramp are working properly or you may end up pulling on it way to hard and it may snap. is the new cable a Barnett? they will stand behind it. did you pull the pushrod and clean it up real good and lube it? did you get the lever adjusted to where the gap at the heal of the lever is the thickness of a dime?
just some things to look at.
