Brake rotor for 2008 k-9
crazall
Hello everyone.... Looking to replace a warped rotor or change out the hub on my back rim so I don't have to brake the bank on buying a bdm rotor. Any ideas? Thanks
superfly
Ride it like you stole it
I just had to get a new rotor myself and went with a PM rotor and had the center hole bored at a machine shop to fit. Problem solved.
mcgroom
If you decide to go PM route, let me know and I will see what I can do to you out with "Forum Pricing".
I am set up as a PM dealer now.
Mick
Your disc is a Brembo or QTM. Are you sure its warped or is it just the rotor buttons are worn out?
crazall
Rotor
Positive that the rotor center is warped. Straght across two mounting bolts. Going to change carrier from front rotor to see if the outer is warped also. Then I will take it from there.
crazall
Changed the carrier to the front and the warped section is so minute that I can deal with it until I get a replacement that I can afford. now I got to order a carrier for the back.
Wild Steed Worx will have quality rotor carriers and the buttons out soon. Keep a eye on our site.
www.wildsteedworx.com
Sent from my DROID RAZR using Tapatalk 2
