Brake problems on my custom
bear1
I recently popped a drive belt on my custom chopper and to change the belt you have to take the rear breaks apart to get them off the rotor. I lost alot of fluid so I replace the two Orings between the two halfs of the calliper. Now I can't get back brakes. I can bleeb the air out but it only locks up the back tire. I still have no brakes and can't push the bike. I have taken them apart three times and can't find anything wrong. Any help?
bearman
if you are sure you are getting all the air out of the entire rear brake system and it still locks up, then you have a problem with your rear master cylinder not releasing completely.
bear1
There wasnt enough room between the rim and the calliper to get it off. I have all the air out but no release. How do I check the rear master cylender
Bobby Schulz
If a piston is stuck you may be able to force it back in by prying between the pad and the caliper. It should move pretty easy.
Kdub
With the rear reservoir cap off you should be able to squeeze the pistons open by hand. If you can't its probably stuck. A rebuild kit may help if its stuck.
bearman
I had a car one time that the inside of of the rubber part of the brake line swelled shut. It would let fluid get to the caliper but not back to the master cylinder. The brakes would drag and overheat.
The master cylinder should release the pressure to the wheel cylinder and allow fluid to flow back when the pedal is all the way up. Check that the master cylinder piston isn't sticking. Pull up on the pedal and see if there is any play in the adjustment. If the pedal is coming back up like it is supposed to then open the master cylinder and see if the piston is coming all the way back like it is supposed to.
