Brake Pads
T.Byrd
Can some one tell me if you can order brake pads for our P.M. brakes on our bikes from J&P Cycles. And if we can which ones are they and the order no.
And which ones are the lbr's you all are talking about, with no dust.
And I looked in the how to on changing the rear pads and it did not tell me much. If some one could explain a little better it would be appreciated.
I don't want much do I . Thanks you all:
You can order the stock pads through Nelson or your dealer.
But I would order the LRB brakes. I only use the Z-Pads but many here seem to like the more expensive Gold pads. The Z-Pads have provided me many trouble free quiet miles. The Gold pads are harder I believe. You can see the differences on the Lydel Brake site.
Changing them is only a matter of removing the pins on the top center of the calipers. Pull the pads then push with a tire iron the puks back. Re-install the new pads and put the pins back in and you are golden.
If you only ride normal you don't need the Gold pads. :eek:
:cheers: :cheers:
