Like I said in this post, the plugs should be numbered. Find plug 3 take apart and with a volt meter red lead to pin 1 or 2 black lead to ground. Then take a jumper wire from ground to pin 4, you should have 12 volts on pins 1&2. If not the relay is not working or maybe the hot wire going to it is broken?
Sent from my Life One X3 using Tapatalk
