Brake Lights Not Working !!!
knothead
Second Chance Customs
Yeah its worked for me too...had it on mine for 7 years now....6 years so far on my other one...so far so good...but ive fixed several bikes with the wireplus and some that i couldnt fix without just redoing everything...i will remove them one day soon to the cleaner new kits that have been out for awhile now...
BigDawg2006
I did this and still no voltage on either pin 1 or 2
Switch is good but this was directed specifically at Big D Florida since he was trying to figure out REAR brake not working but front ok.
But it does eliminate on more thing. Next you need to get to the EHC/WP and ground the pin there and if lights fail then (assuming they are wired correctly) then the module is probably bad and you could fix with a relay.
Like I said in this post, the plugs should be numbered. Find plug 3 take apart and with a volt meter red lead to pin 1 or 2 black lead to ground. Then take a jumper wire from ground to pin 4, you should have 12 volts on pins 1&2. If not the relay is not working or maybe the hot wire going to it is broken?
Sent from my Life One X3 using Tapatalk
