Brake and throttle cable hitting tank when bars turned turned
Exotic
I did a search but it didn't turn anything up. When the bars are turned full right the ends of the cable right after the 90 degree metal bend in the line hits the tank. I put touch up paint on it, but it does it again:bang:
Is there an easy fix for this?
barhopper
Another round please
Could it be the bushings? My bushings went bad and did the same thing. New bushing and the bars were where they were supposed to be.
rackman
You said 2 bolts. There is a set screw that you should tighten if you moved the controlls with the 2 bolts, otherwise the set screw will come loose over time and your controlls will will rotate while you are riding.
Guess how I know.
