Braided spark plug wires
Rich9426
Hey guys I am about to change my spark plugs and wanted to change out the wires also. I wanted to change then to braided chrome. I hav a 2003 Bulldog that has 8.8mm Accel on the bike now. Can you guys make any suggestions on where I can get the new wires? Also can you suggest an upgrade, size,type, etc? Thanks.
paleskin
Rich,
I can't offer solid advice on this issue other than to share my experience. I think the wires BDM chose are an "off size" meaning non standard (8.8 mm I think), many have tried to change out wires and there have been mixed results. When I changed mine out, the bike immediately began having issues where it would just die. I would still be rolling and simply turned the key off then back on and refire the engine and it would run fine for another variable period of time before it would happen again. I finally gave up and went back to stock wires with much better results. I would do the maintenance work and run the bike to make sure all the work is fine then change the wires so that if you do have a problem, you can isolate it directly to the wire change out rather than thinking something else is wrong (like the EHC might be bad.....yada, yada)
john sachs
Braided plug wires............ 1 word JUNK !!!!! :eek:
The 8.8's on the bike now are probably the BEST money can buy. :2thumbs:
John
