bikes dead
U
Underdog
Guest
It drains itself dead. Won't charge. Has to boost it 3, times on Sunday. Removed the battery, charged it fully and load tested it at 800CA. Someone please help...
Brew
Get the thing started and check the battery terminals with a multi-meter with it running. Should have near 14 volts DC with it running. If it's low then your charging system is whacked. Do a search and find the thread on troubleshooting your stator and Voltage regulator and determine which is not working. If the volts are good then your battery is whacked...
