checked the jets have .78 main .33 int , must have a vacuum leak, or breather system hooked up wrong.
This auxiliary bowl vent screw is on the outside of the carb, the bowl does not have to come off to remove this, and then readjust air/fuel screw and idle if necessary if vent lines are hooked up correctly.Did you remove the auxiliary bowl vent plug the bowl does not need to be removed to remove the vent plug it's circled in green
Glad ya got it figure outjets were fine, It helped to connect the breather system correct, its hell getting old. Thanks for the help.
Thank you for your helpGlad ya got it figure out![]()
Thank you for your helpDid you remove the aux Bowl vent? Check the jet sizes, with my wimmer dual spike .33 int and .78 main work perfect and I know a couple guys running the dual runner are using the same size jets
