bike does not idle steady and bogging bad
mark6747
my idle issue, a big thanks to ( MOBSTA ),!!!!!
after everything i have been through with this FN idle issue, the fourth time in the shop, BIG DOG of tampa fl. found the problem,!! it turns out to be a bad CARB. it is catching air from the shaft that goes through the carb. that holds the throttle butterfly plate on the inside the carb.. ONCE AGAIN I WOULD LIKE TO THANK EVERYONE WHO REPLYED,, AND A BIG TIME THANKS TO,:cheers: MOBSTA :cheers:, everytime i had a tech. issue he was there to help,, WAT TO GO ( MOBSTA ):cheers::cheers::cheers:
mobsta
i think you mean accelarator pump,gettn on the throttle it can,the idle may have been a fuel mixture adjustment:)
mark6747
well i noticed the idle issue when i went to bike week it alot of stop ang going in traffic, it would idle up a little when i got into the throttle a little, well lets just say the best i can with the way it was running with what ever that throttle screw that was lean, could it have been loading up,??
