Thanks Bad. Here's the scenario...was riding with JeffM last Sat and part of the ride had the absolute bumpiest road I've ever ridden. Shortly after the road smoothed out I noticed the vibration which forced me to slow down to 60. Thought it could be the dyna beads but when I pulled the clutch in the vibration stopped. After lunch, Jeff grabbed his tools and the coil bolts were tight. When I got home, I couldn't find any obvious problems so I pulled the primary cover and the clutch basket, chain and pulleys looked fine. Plugs looked good. Motor to frame bolts are tight. Tank bolts are tight. Exhaust is tight. Rear fender is solid. No unusual engine knocks or sounds. Whether riding or sitting still, the vibration starts at 1500 and at 4000 feels like its going to fly apart. The search continues...Everything is subject to come loose on a dog!!! As you're riding, squeeze your legs against your tank(s) and see if that helps. My tank bolts have vibrated loose and is sounded like hell. Check the top bolt of the coil to the frame. It's notorious for vibrating loose. Pull your derby cover and check your primary chain for proper tension.
You better hope she never reads this ,, she will kick your azzI had a similar problem with vibration and lost my top motor mount bolt within 30 miles or so. This happened at Sturgis about 3 years ago. The problem was that the Bike was running rich. At the time I was using a Big Air PSI Carb, made the adjustments and it was all good for the rest of the Trip to Sturgis. At first I thought my wife had gained to much weight and the dog was struggling to haul ass. :lol::lol: But it was the Carb Setting and wife never found out my thoughts. :lol: Check out you plugs and see if you are running rich.
Carlos
Carlos.Good call Claw! I have had a nasty vibration since day one. My feet would vibrate off the pegs at 3200 RPm's and went away after pulling in the clutch. I found my center bolt on the Coil cover was bottomed out as well. I have been checking that s.o.b. with a torque wrench forever but also found it to be misleading. I have not test riden it yet but I will bet it takes care of some of my vibration problems. Thank you brothers!
steve, there was a factory service bulletin that came out in regard to the clutch hub nut with a specific sequence to perform.Torque for clutch hub shaft nut is 80 ft. lbs., I am also looking for the source of new vibrations which go away completely if I pull in the clutch. I am about to do some major teardown as a preventative. I will post if I find anything.
