VMAngelR
My Bulldog died after jumping a bump at about 60MPH, I noted the positive battery terminal was little loose and one cable was about to break. Problem remains after fixing the cable and tighten the battery terminal, check battery OK, check Circuit Breakers OK, check fuses OK. Seem I finally need to replace the EHC on my 07 Bulldog, I did some research and found 3 available options, the EHC retrofit Kit by Wire Plus, the ESC plug n' play by Dead One Customs and the EHC RIP by Kansas Motorcycle Customs. The plug and play ESC by DOC seem the most attractive and sturdy alternative to me.
Any experience with these modules that you can share? any suggestions?
Thanks!
Thanks!
