zz chopper
Knothead ... this is zzchopper ... I have throttle cables that I can not use after changing handlebars on my 2004 ridgeback. They look like new. Both cables for $50?Yeah you did now that i think about it
So if I am actually in the market for an Ultima open primary someone tell me which one specifically I am looking for I can’t seem to find an ad that says this one will fit Kelly’s 2004 big dog choppervSs 107 lolFWIW,
My experience over the years, has been that Ultima makes some EXTREMELY GOOD parts, and pieces, especially in the Engine department. Also they handle most of the same brand aftermarket parts, as the other warehouse distributors do. I also find that user error, a lot of the time on any part, becomes the fly in the ointment.
John
Pretty sure this is the 2” Ultima model. Requires you to adjust the transmission to align with the motor face. Pretty straightforward & plenty of vids on youtube to guide you along. Not super expensive.So if I am actually in the market for an Ultima open primary someone tell me which one specifically I am looking for I can’t seem to find an ad that says this one will fit Kelly’s 2004 big dog choppervSs 107 lol
The DT chopper is also 1 7/16 as well.The reason Eric asked is because the 04 ridgenack is a 1 7/16 offset primary...04 mastiff and 04 chopper are a 1 1/2 offset primary
Beat me to it. When I put that Ultima on my 03 Chopper with the DT frame, I had to machine the spacer down to 1 7/16The DT chopper is also 1 7/16 as well.
Sent from my SM-G991U using Tapatalk
If you have a’04 chopper you will need the 1.5” spacer.So when you bought a Ultima for the 03 chopper. it came with 1.5" spacer? and you machined to 1-7/16? and it bolted up?
I have a 04 RT Chopper and looking at Ultima for the money to see what I Think.
Yup. That’s it.So the basics are
1.5" spacer https://www.ebay.com/itm/264514352303
1.5" pulley spacer https://www.ebay.com/itm/263534407789
and the belt drive it self thats it?
remove outer primary, compensator, clutch/ basket, and inner primary. then bolt ups that, and Bam done?
Plenty of them out there to be had. Not cheap but they are available. Heel guard isn’t necessary in my opinion. But to each his own. If you’re going to pop for one the sooner the better. They ain’t going to get any cheaper that’s for sure.Also I was just told Ultima sold out to Vtwin so not sure you can order stuff from them anymore?
