Battery side cover
bigchazz
Looking for the cover around the battery/eletrical. Mines cracked and would like to replace. I have heard these also called side covers. This for a 05 Pittbull...anyone know where to look for this.....thanks
Give Bob Lockwood at BDPP a call. Last time I was there he told me about the side cover fix they have available. You have to cut the existing tabs off of your covers and then glue the covers to a replacement piece. Not sure on the price..... may be eaiser then finding new ones?
Tim
Founder
Lifetime Supporting Member
Just ordered both sides from member and sponsor bigdogpartsking for my 07 k9
Sent from my SPH-D700 using Tapatalk
CurtK
Side Cover fix
I found one side cover tab broken completely through but still in place and the opposite had a sizeable crack. I used Super Glue to put pieces back together and then brought to a friend of mine who added some fiberglass to the inside of the covers and they are as sturdy as ever now.
Curt
Kdub
I drilled holes at the end of all my cracks then jb welded the shit out if them. Holding for now. These are the biggest pile of garbage BD ever created. I wish someone would make some out of metal. They would make some good money!
Nukeranger
Nukeranger
Yep, this is very common and when superglue doesn't work, JB weld does. Here is my JB weld job which should last a very long time. I still have to get it sanded and painted but it is under the seat so there is no hurry.
kickstart
YEP :down: had 3 or 4 sets replaced on my Bulldog
spadesluck
My chopper did the same thing on the battery side. The top tab broke off and all I have left is the bolt and rubber grommet. Going to make a new tab eventually, does suck though.
