U
Underdog
Guest
Has anyone had something drawing their battery dead? Think I have that problem. I have an '09 K9 carbureted.
:2thumbs::2thumbs:How much DC current is the bikes system drawing when the bike is sitting?
It should always be connected to a Battery Tender or similar maintenance type charger designed for MAT type batteries when you're not riding.
Disconnect the (-) battery terminal. Set the digital voltmeter (DVM) to read DC current at less than 10amps. Connect one meter lead to the (-) battery terminal and the other lead to the all of the battery ground wires that were connected to the battery terminal.
You should read less than 75 mlliamps as a guess. The EHC will draw some IDLE current when the bike is off.
Thank you. I will try that.How much DC current is the bikes system drawing when the bike is sitting?
