bandit bruiser clutch
racer1
I just ordered a Bandit Bruiser clutch today too. I hope it fixes my constant clutch slipping problems. It is embarrassing when a Honda passes you.
A while back my clutch hub broke too. I replaced it with Bakers up-graded version. While ordering the hub they talked me into their 9 plate clutch and I installed all the parts and the clutch slipped bad. I re-installed the old 12 plate and it worked fine for a while and eventually started slipping.
I should have my Bandit next week and will let everyone know how it works.
Again thanks to everyone on the forum for good advice.
racer1
I am a little slow and just got around to installing my Bandit Bruiser clutch.
About 4 hours and a few cold one's it was successfully installed.
I followed the instructions and even trimmed the cover and it was not that bad at all. I installed two .050 shims under the springs and adjusted the clutch accordingly. The adjustment had to be tight to get it to work. I did a half turn on the clutch arm and minimal free play.
Took it out for a test ride and it does not slip at all. I really like the clutch so far.
Thanks again for everyone’s advise.
