Baker 6 Speed (LSD) Diagram
Five Five
Does anybody have diagram of the Baker 6-speed overdrive transmission (LSD)
Pulled my primary to access the Trans Drive Pulley...thought the nut had backed off, everything was good in regards to the nut, but the drive pulley shaft has about
0.075" play....little concerned about it.
Thanks, :bang::bang:
bigdogtech01
Are you stating that the Main drive gear or main shaft has that much play? If either or both have any amount of play you can feel, it sounds like your transmission needs a rebuild with new bearings.
