Ran into something today while putting forward controls on a bagger. The first thing you will see, is it has 3 dowel pins instead of just one. No problem there, just take two of them out.
Here's were the problem is. those two pieces need to fit together. The part on the bagger measured .963'', and all the other Dogs that part is 1.010''.
So I put it in the lathe and made it 1.014''. Problem solved.
I called and talked to Derrick and Eric about this. So if you decide to put forward controls on your bagger, it will come with this part already machined out to fit.
