Bad vibration
bama6872
As I decelerate the whole bike vibrates. If I pull in the clutch it smoothes out.
Once when I got in the throttle good I noticed slippage. Is this a chain or sprocket out of whack? Thanks in advance.
bama6872
This makes sense being that I just had a new clutch cable installed. Maybe the installer didn't tighten it firm enough. Thanks guys
TapioK
The clutch nut guys are talking is in the middle of the clutch, under primary cover on the left side of the bike and it has left-hand thread. Replacing clutch cable you work on right side of the bike. Clutch nut should be tightened to 80ft lbs if I remember correctly, with red locktite. If I'm wrong with numbers, someone will correct me...
TapioK
Kind of sharp vibration may be caused by loose upper engine mounting bolt too. Also 80ft lbs. With red locktite.
tighten to 150lbft dry, remove nut, add red loctite, and tighten to 120lbft. let it set for 24 hours and then add the oil.
