back wheel problem
mickeylondon
I guys help needed I changed the back wheel on my 05 ridgeback and when I try to put it back on it kinda goes sideways I got the spacers in the right way I am sure as they wont go in any other way can someone tell what I am doing wrong thanks guys
thanks I got it sorted now
Accidently put the spacers on the wrong side?
Remember there are two on the left one goes between the hub and the brake caliper and the other one goes between the brake caliper and the frame. The easy distinction between the two is one has a lip which faces toward the bearings.
mickeylondon
a bit stupid really when i pushed the shaft out I dropped 1 of the spacers and did not notice so when I tried to put it back it would not fit till I found it on the floor lol it went on easy then
bearman
Like the saying goes, if you don't make a mistake sometimes, it's because you are not doing anything.
