Five Five
MOE...put down the crack pipe and take a breather..Oops sorry, no swingarm, no pivot bolts.
:roll::roll::roll:
hows your mono-shock project going...
Jackal....glad it worked out for you...kinda scary though, time for you to do a once over to make sure everything is tight....5 5 bingo last night did not look at it very close ,, adjusting bolt and set had backed out on
right side of bike ,, when i put wrench on axle nut whole wheel had movement,, axle bolt was not tight at all kinda got my hair up on my neck.. thanks for all the response gotta tackle that speedo now lol
here is the calibration procedure for your speedo...it looked to have gotten moisture in it had power but needle peg out as soon as i started bike and od. didnt work i just got finished putting the knew one on it powered up went to 60 then back to 0 like it should will be tomorrow before i can test it out , need to check trans. fluid also have not checked it yes
Jackal....glad to be of some assistance...now get out and ride :up:thanks again 5 5 i guess i will have to mark out a 2 mile stretch the paper work says it is pre calibrated at 80,000 pulses per mile . thanks again
