Autometer Speedo Help
shooter
I need some help with a autometer speedo, my bike is a '02 Bulldog, I searched the forum and the calibration instruction i found are apparently for the VDO speedo. the speedo on my bike appears to read 15-20 slow, when the ignition is turned on with the trip button held down odometer reads calibrate, pulse, autocal.....when pulse is selected 65000 was displayed i adjusted to 135000 a figure i found in the earlier post this made error much greater so i tried 58000, and 53000. 53000 seems to be closer. does any one have the correct pulse count or the auto calibration procedure for this speedo?
Thanks in advance
Rick
Top1371
Manual says the pulse count for 2002 softail models with the 65 tooth pulley is 060,000
For models equipped with the Baker 6 speed 049,000.
shooter
Thank you, Gunny for that info I'm gonna try it out tomorrow 49,000 sounds like it will work the 53,000 was still too high
Rick
