anyone have/used one of these?
dcam
Just installed a new regulator and a DOC charging fault light. Curious if anyone else has used the light. Thanks
www.deadonecustoms.com/BDM Accessories/BDM electrical accessories
Thanks for posting this link. I like the idea of the intermittent flashing while the battery is recharging after firing her up, if it does not go out then I know to head somewhere to work on 'er before she shuts down! :whoop:
A hundred bucks seems pretty steep but let us know how it works out and show us some pics of it installed if you can, because I am trying to figure a place to put one myself! :up:
U
Underdog
Guest
It mounts inside by the coil, right below the key. You can't see it unless your on the seat. From there it has a braided line into the back bone. Installation is very easy if you don't have to remove your tank to get to your backbone access hole. Took me an hour to do. I'll take pictures when i get home from work.
BigDogBro1
Made in the USA
Brew
I have it installed and love it. It only comes on when the battery is weak, charging system is over volting or under volting. Works just fine! Been running it about a year and a half and its notified me of a failing battery already....
