Anybody know
rschubel1957
need to change the rear brakes.have to drop the rear wheel anybody know the tention on the belt when i put it back together?
rschubel1957
its got the same brakes as all the others do but the caliper goes around the roter and the pully so thats why the wheel needs to come off . i allready have the pads i just need the tention on the belt?
I'd say no more than 10-13lbs on a tension gage. Set it as you see fit and go for a ride. It ain't gonna sling off if its a bit loose, but you will feel it. You may adjust a couple of times to get it where YOU are happy. Jm.02
Shredder
HMAN is correct, I have a 2009 Wolf and you set belt tension with the Harley belt tension tool to about 10 pounds of force. Very easy.
